karn
- United States
- Electrician
I was called out to look at a panel located in a mechanical room for an indoor pool. The room is very humid and full of corrosive pool chemicals and equipment, including the pool pump, filter, and heater. The current panel is inside a stainless steel enclosure that may not be readily accessible without a 5/16" bit to loosen the latch and open the door. However, the fire marshal is more concerned with the lack of encasement around the dead front and the exposed wiring. Any recommendations for solutions or replacement options?
