I’ve got a newly installed fan support that ended up being 1” above the ceiling finish.
It’s on a outside porch and the ceiling finish is aluminum soffit material.
Siding contractor ended up firring down the trusses 1” and never said anything. I could have easily lowered it.
Removing the ceiling at this point isn’t an option.
Was thinking about cutting a 4 1/2” dia disk out of a 1” thick pvc plank and then drilling out the center 3 1/2” for the wires to pass thru.
Would use 2” 10/32 screws and sandwich the disk.
Thinking the PVC would be better than wood.
Ceiling fan weighs about 20 lbs.
Thoughts?
Thoughts?
