Low hp DC motor starting
jminer99er
Sacramento, CA
Im adding a new ¾ hp DC motor at 24Vdc to a hydraulic unit. This will be remote operated via mometary push buttons.
My questions is DC rated contactor/motor starter options. The motor is 3/4hp 1800rpm, 4pole, 24Vdc. The nameplate says A.ARM 31.8. I was thinking like nema 2 contactor, but I'm not sure if it's DC rated and have options for 24Vdc coils. Im not fimilar with dc motor starting. What would be some starting installation options? 1000022119.jpg
Yes I understand that, does anyone know know of a dc contactor/starter that is rated for 31A @ 24V from a reputable mfg, or will I have to use this type of solenoid?
May not be exactly what you want but talk to your local supply houses. They should be able to answer your questions as they relate to their products.
Try Grainger.
Try Grainger.
Line side is a/c. (Im familiar with nema rated contactors, but not sure if they're engineered for dc loads) Attached is what I'm finding for a dc contactor. It looks overkill for a ¾hp 24v motor?
Im adding a new ¾ hp DC motor at 24Vdc to a hydraulic unit. This will be remote operated via mometary push buttons. If I loose shore power I can use dc power for emergency to drive hydraulics.
My questions is DC rated contactor/motor starter options. The motor is 3/4hp 1800rpm, 4pole, 24Vdc. The nameplate says A.ARM 31.8. I was thinking like nema 2 contactor, but I'm not sure if it's DC rated and have options for 24Vdc coils. Im not fimilar with dc motor starting. What would be some starting installation options? View attachment 2579253
IFIFY. Small detail that should have been included.
The only power I've ran on anything that floated were oars.
Please note 90.2(B)(1)
