brantmacga
Señor Member
- Georgia
- Former Child
That’s pretty cool, but I don’t see the benefit of it. He still can only use two things at once unless it is extremely small cord and if that’s the case, I’ll just break the tap.
Better than what I found when searching!Wife acceptance factor - Wikipedia
en.wikipedia.org
if the horizontal doesn't exist it doesn't exist, and I've done my due diligence to prove it isn't available.
Adorn Pop up receptacles require 3-1/2” deep for 2-gang boxes.There's something funky about the 2gg and I can't remember what exactly
It looks like two of the outlets are switched. From photos on the web I have seen, in some other countries switches built into the outlets, so each outlet can be turned on or off. That would reduce power use by electronics when not in use, and protect it from voltage spikes when not in use.That’s pretty cool, but I don’t see the benefit of it. He still can only use two things at once unless it is extremely small cord and if that’s the case, I’ll just break the tap.
prado.com
It looks like what it is: an extension cord end.Another expensive approach just crossed my feed:
prado | invisible home technology
prado.com
They have a duplex style
prado.com
Yeh i saw these and ordered one to put in my island. Wife said i cannot cut an outlet anywhere into her black walnut but i need somewhere to plug in my laptop charger when I’m sitting there so I’m going to put it under the countertop. Fully aware the overhang makes it not code-legal but it’s not for appliances and will be hidden from view. I’m just going to wait until after my final inspection to install it.
I've wondered if something like a boating 'skeine chock' https://www.google.com/search?q=skene+chock would work to capture the loose wire and prevent the hanging wire risk
