Derating is using the conductor insulation maximum temperature value not the terminals. So for something like THHN you can use the 90° C ampacity for your derating calculation.
You start with the 90°C ampacity for the ampacity adjustments and corrections. If that results in an ampacity that exceeds the 75°C ampacity, you use the next larger conductor for the installation.
