240 volt Dryer controls 120v booster fan?
sw_ross
NoDak
If a booster fan was needed due to a long run of venting how would you control the booster fan by automatic method so when the dryer turns on the 120v booster fan kicks on?
Thanks!
All the booster fans I have had to run power to have just required a constant hot receptacle. They sense the air flow from the dryer to turn on/off.
Pressure differential switch would work as well. We are talking ones that have settings in the inches of WC for the set point. Though lint build up could be potential problem for performance of both pressure and a sail switch, I would think it would be more of a problem for a sail switch.
Home Depot had that problem with the ventilation proof switch in their tool rentals, which was a sail switch. Dust build up would weight down the sail switch. I Changed it to a pds like you mentioned, and didn’t have any more problems.
