- Bremerton, Washington
- Master Electrician
WA labor and industries has a proposal to change NM-B ampacity for 8 and larger to be the 75 deg C rating in WAC 296-46B. Pubic comments will be accepted Oct 7 and the final rule will be issued Dec 19
It will be interesting to see comments but there are likely many EV charging stations on 8 NMB at 60 amps
Link https://lni.wa.gov/licensing-permits/_docs/Draft-Rule-Language-Version1.pdf
Advantage is for 6 NM-B on a 60 amp circuit for EVS.
