Installing 200A main panel in an outbuilding. I have to run 200A direct bury wire (4/0-4/0-2/0) from the emergency disconnect to the (65') building and stub it up, the LB it through the wall then run in conduit to the utility room (another 40')
However, there is an underground pipe, 2" white plumbing PVC" that stubs up in the utility room, and runs under the concrete slab and exits through the footing of the garage. If I could muster pulling the service wire through this, it would substantially simplify the installation.
I realize that white plumbing PVC is not the same as conduit, but could it be used in this application that is nearly all underground?
