Superdemon
- New York
- Electrical Engineer
Assuming minimal connected load required to reach optimal efficiency, is there a general rule of thumb for the transformer efficiency of non-DOE compliant dry type transformers such as non-ventilated ones smaller than 15 KVA?
I'd like something to use when doing voltage drop calculations involving transformers. It would also be great if there was some generally accepted documentation for this but I have not found anything so I assume there isn't any.
