- Bremerton, Washington
- Master Electrician
Anyone use these, do they work what is the cost?
UL Rep at IAEI meeting today, said UL just finished publishing a GFCI standard for the high frequency.Ecmag.com
The CPSC supported proposals, dated Nov. 22, 2024, to revise UL 943 to address high-frequency GFCIs.
As far a I know, there is none on the market at this time. UL-943 just recently updated the standard to provide for GFCI-HF.I hate to bother my old suppliers with cost questions when they know I won't be buying.
Can one of you active members come up with costs and catalog #s?
Based on the information provided in the UL-943 meeting when the GFCI-HF was adopted, that does not appear to be the case. Most of the issues is the high frequency leakage current that is created by VFDs.It may be too little too late, since developers have entrenched appliance OEM’s that work with old GFCI’s.
Did that meeting clarify when NRTL is required for UL-943 GFCI-HF adoption?Based on the information provided in the UL-943 meeting when the GFCI-HF was adopted, that does not appear to be the case. Most of the issues is the high frequency leakage current that is created by VFDs.
The standard is complete, so as soon as manufacturers can complete their design work and start manufacturing them, they can submit them for testing so they can be listed as a GFCI-HF.Did that meeting clarify when NRTL is required for UL-943 GFCI-HF adoption?
Did that meeting clarify if GFCI-HF devices will be sold separately from Non-HF GFCI devices?
Thank you kindly.Some on the UL-943 committee wanted all of the GFCIs to be of the HF type, but that did not pass ballot.
