Time-delay multimeter fuse
Electromatic
Virginia
Master Electrician
I blew the 500mA fuse in my multimeter. This is (obviously) for the mA/µA setting. There are a lot more and cheaper options for a time-delay fuse in this size and rating. Any opinions on whether using a time-delay for this small-range setting is hazardous?
TIA
Usually multimeters need very fast acting fuses to protect their electronic components. Such fuses are typically expensive, but still quite a bit less than a new meter to replace a broken one will cost.
If your meter has a CAT rating, I would stick with the recommended fuse.
Not worth possibly causing an arc flash.
I've blown two fuses in Fluke 87s. One when I was doing something Gar told me I was an idiot for. Nicely put, but he was right. The meters and I both came thru unscathed. I'd be nervous with $0.99 fuses.
Ten for 99, that's only 9.9 cents per fuse
Wasn't it the Simpson 260 that had a protection resistor on the board? When they blew you had to solder a new one on
I've got that walmart plus membership. I've got to say they have treated me good. Returns are so easy, it's like dealing with Sears back in the 70's. Most times if something is wrong or damaged even in the slightest way, even if it's a pack of 100 of something and only 1 is damaged, full refund and they tell me not to return it.
I bought a little 5000 BTU window air conditioner for a small office. It seemed to cool good at first but then it would only get the room down to 65. I called The manufacturer's customer service and asked for tech support, they asked me for the Walmart receipt, and a picture of the ID sticker. I emailed them that and they refunded every penny. and told me to, throw it out, or donate it, or whatever I wanted to do with it.
I just wanted to know how to check all the settings, or reboot something, a few easy checks. They didn't even give me time to ask. I got the refund, figured I had nothing to lose if I opened it up, so I took the cover off and found that the temp sensing unit was a little out of place, bent it away from the evap coil, and it worked fine.
They had me off the phone so fast I was almost disappointed until the money went back on my card 2 days later and then I felt better
The one I need is a 5x20mm which returns even fewer search results that the 6x32. Taking mA readings on 12V or 24V control circuits seems pretty unlikely to cause an arc flash or other catastrophe. I understand the possibility of damaging the meter, but it's a fairly cheap Klein. I'm wondering if a time-delay would prevent blowing on a momentary lapse of attention or slip of the probes.
Yea, if you only use it for 12 or 24V, I would probably look for cheap fuses too.
But not if its ever used for commercial or industrial line voltage system. Although, if it doesn't have a CAT rating, it shouldn't be used on those systems anyway. Too easy to try and measure voltage while it's still set for a current reading.
That could add unwanted excitement to your day!
