120V required in the NEC?
pipe_bender
Boston
Is there anything in the NEC that requires a 120V receptacle (or 120V anything else) at other than a dwelling unit?
Say a cold storage warehouse building, or parking garage with a 480/277 service, and everything can run off 480 or 277.
Its a secure location, few employees use it but large building, 277V lighting, access control, fork lift charger all can be powered off 277. It does have a ADA bathroom.
is some 120V required by the NEC like a GFCI ?
I know its stupid not to have a 120V GFCI but does the NEC require it as 'code minimum' ?
The office is in a totally different building that has 208/120.
Thanks
Also 210.64 & possibly 600.5 although that requires a circuit and not necessarily a receptacle
