Hello, in the Canadian Electrical Code there is rule 28-104(1)(c) which requires motor feeder cables to be sized based on 75C ampacity values. Is there an equivalent rule in the NEC? Is there a derating factor to apply to the values in the 315.60(C) tables to get a 75 C ampacity value? For example, the corresponding table for shielded 5 kV cables in the Canadian code uses a 0.886 factor to convert from 90 C to 75 C values.
Thanks.
Thanks.
