Mgilc003
- virginia beach, va
Hello,
Recently I was contacted to replace an inverter for emergency back up lighting on high bay light fixtures.
The previous inverter was bypassed and turned off when I did my initial assessments and let the smoke out as some as it was turned on.
Today we were commissioning the new unit with DSPM and the inverter does not switch back to line power once it is restored.
They recommended installing an isolation transformer because according to him there is an issue with the neutral wires on the load side of motion controls to one of the lights.
He described it as either a secondary to ground or a different issue. I ohmed out the load neutral to the line neutra when it was disconnected and read OL but I guess it possible there is a very high resistance path to to gound.
The other guy on the phone mentioned motion sensors or photocells could cause an issue.
But the thing is there is a mirror unit on the other side that does not have an issue and is working without an isolation transformer and with motion sensors.
Wondering about your thoughts. Installinh and isolation transformer sound like masking the issue.
