2 wire start conductors with power conductors
Is there an NEC issue or is this just manufacturer instructions?
To answer that you would need to know if the start circuit is a Class 1 circuit or a Class 2 circuit.
Given that most of the start circuits I have seen use the generator starting battery as the control power, it would be a Class 1 circuit and could be mixed as long as the control circuit conductors have an insulation equal or greater than the voltage of power circuit.
