dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
My house is older mostly ungrounded circuits. I was going to redo some wiring. 1st floor to partially finished basement, suspended ceiling. The basement walls are built up and out in the basement for drywall insulation etc. this makes it very improbable to go up from basement. So its likely i will go from first floor to basement with some flexible bit. In the past my previous old house I used the 3ft klein flex bit but it still made a little rod burn at the top of the hole and was hard to keep bent even with bending tool while drilling. Attic access for some outlets will not work tight point in A frame. Any recommendation on flexible bits that have worked well for anyone. My right-angle drill is larger chuck height than box size.
Thank you
			Thank you
