D. Castor
- Port Angeles, Wash
- Electrical Engineer
You seem to be hung up on the role of ambient temperature in the determination of conductor resistance. Obviously conductor temperature is affected by the ambient temperature. BUT - when the CONDUCTOR temperature is explicitly DEFINED as a data input, as it is in both SKM and Easypower, then that is the conductor temperature used to determine the resistance, regardless of what you specify for the ambient temperature. How could it be otherwise?
How would it work if you explicitly specified a conductor temperature of 75 deg C, but then you changed the ambient temperature data and the software adjusted the conductor temperature to something else? This would not be workable.
It's been an interesting discussion, but I don't think I have much more to add.
