TwoBlocked
- Bradford County, PA
- Industrial Electrician
That doesn't appear to be a low spot in the run so do you think that the entire conduit filled with water? If not I don't see that being from freezing. Looks like it rusted out before it split.Came across a split conduit that I have to assume was from frozen water. Yet how could this happen in this instance, and in general, how do you provide drainage for conduit that goes underground?
I don't know just what to think. have you seen something like this before? EDIT: I saw a very similar split on a conduit that we are pretty certain was from water freezing.That doesn't appear to be a low spot in the run so do you think that the entire conduit filled with water? If not I don't see that being from freezing. Looks like it rusted out before it split.
You bury a "T" condulet?At some low spot in the run we would provide a French drain (say a 2'x2'x3' hole with stone) with landscape cloth below the conduit and a "T" fitting for water to drain.
Which gas company your working for?Came across a split conduit that I have to assume was from frozen water. Yet how could this happen in this instance, and in general, how do you provide drainage for conduit that goes underground?
View attachment 2580487View attachment 2580488
None. I work for a contractor.Which gas company your working for?
Yes. I have also done similar to the detail Don shows.You bury a "T" condulet?
Rob G
Seattle
What kind of place is that your working at, looks like a meter/regulation skid or something of that.None. I work for a contractor.
I'd rather not say. Consider it all to be hypothetical.What kind of place is that your working at, looks like a meter/regulation skid or something of that.
We traced an issue like that for a couple of weeks in a tank farm. It was an I/O circuit and late in the day when the ice would melt, the conduit would relax and cause a short circuit, then later when the water froze again the split would get larger and the short would go away.
