- Tennessee NEC:2017
- Semi-Retired Electrician
I installed over 100 LED recessed lights in a new construction home about 3 years ago, in 2022. Starting in 2023, several of the lights have either totally stopped working, are intermittent, or flickering/strobing. The vendor has replaced them under the 5 year warranty. That is good, but I get no compensation for my labor. I think I have replaced 40 or 50 of them.
There is no pattern of where the lights are failing. They have failed all over the house, from top floor, main floor, basement, and outdoors. Voltages appear good, connections are tight, no other electronics in the house have failed.
I replaced all the lights in a high ceiling with a different brand as they are the hardest to get to. Two of them failed less than a year after being replaced.
Is it just bad lights, or is there something else causing this?
