There is also the problem that supplies of helium are limited and 3He is only present in trace quantities in helium sources. There's probably not enough of it around to enable us to do anything with it.
That is the reason given for mining it from the moon.
If we actually had a working fusion system, the amount of
3He needed as fuel is plausibly small enough to make it worth bringing back from the moon. The benefit of using
3He for fusion is that the reaction doesn't produce neutrons and thus doesn't 'activate' the walls of your reactor.
With all that said, I'll repeat that we don't have working fusion reactors, and if we did I expect that they would likely use tritium (
3H) as fuel. We can make
3H from lithium by bombarding the Li with neutrons. So if your fusion reactor has a lithium breeding blanket in the walls you use the fusion neutrons to make more fuel. (No this is not a solved engineering problem, just like the entire reactor is not a solved problem. But we at least understand the reactions so we can make guesses as to what might work.)
Also if you have copious quantities of
3H available, you will solve any shortage of
3He.
3H is unstable and decays to
3He over time.
Separate note: the thing about limited helium supplies is also a funny on. We have more helium available on earth than we could possibly use. The problem is that most of it is simply very expensive to capture. The cheap easy to capture helium is found in natural gas wells, and that
cheap helium supply is very limited. But the amount of helium simply floating in the air is staggering. If we were willing to pay 10-100x more for our helium, then we won't run out.
