We need to install a service disconnect, and the only available space is above another disconnect, but we're about 8 inches short of the required 6.7-inch height. Our idea is to add a concrete step to raise the floor in front of the disconnect.
The question is whether this step is sufficient just in front of the disconnect, or if it needs to be extended to cover all the existing equipment on that wall (meters, disconnects, panels). Also, is there a code that defines the required depth for this step.
