bigalbert
- Stafford Springs, Connecticut
- Electrician
I was troubleshooting a single switched outlet in a living room. The circuit is controlled by a 15a AFCI breaker. With nothing plugged into the outlet and the three way switching is off I am seeing 52 vac from line to neutral and line to ground at the outlet. Both three way switches were replaced but it made no difference. When anything is plugged into the outlet even though the switch is off the 52 vac goes away. Is this just standard operating for an AFCI circuit ?
