- Tennessee NEC:2017
- Semi-Retired Electrician
Would you consider an electric fireplace insert fixed in place space heating, or a space heater at all? Some are just decorative, or for ambiance.
I would say no. Mine cycles the heat on and off every few minutes, while the artificial flames (a light show that uses almost no power) is on constantly.Mainly just trying to see if it would be considered a continuous load.
What is the watts of your heater?I would say no. Mine cycles the heat on and off every few minutes, while the artificial flames (a light show that uses almost no power) is on constantly.
25A @120VACI'd imagine a small gas / propane or wood pellet fireplace / insert delivers about 20k BTU/h ~= 6kW of electric resistance heat equivalent to a room.
If I were replacing a supplemental room 'fireplace' heater and switching the fuel to electric my guess is you'd want at least a 3kW electric resistance heater/fireplace, presumably there would be ductless mini-split or some other primary heat source.
