Where are the details on the invoice ? Anybody can make up an invoice in less than minute and thirty three seconds.Sorry I got invoices with some info I thought was removed.
Nothing on that electricians invoice backs up homeowners assertions of a pre-existing condition. Doesn’t sound like that electrician wants to go on record saying anything too definitive.Where are the details on the invoice ?.
You sell a car to Customer X. A year later Customer X calls you up and says, "I took that car you sold me down to Paul the Mechanic because I wanted him to install a new distributor cap and while he was installing the new distributor cap the whole engine caught fire so Paul put a new engine in and now you owe me $4000".A lot of people here are saying to stand on principle and I completely understand that.
But...
I would also want to share my opinion on one thing.
Sometimes it is cheaper to pay it and move on. Your time is $. The effects worrying about it is also a factor.
I have had people point fingers for HOURS with emails back and forth when the remedy was cheaper than finding fault. If you would rather not think about it and you are too busy to go back and forth with them, then maybe just have a lawyer draft something and have them sign it for the check.
Or level with the other electrician and try to get it paid for by the both of you to avoid problems.
Ultimately, you have a decision to make and I don't think going either way is wrong. Good Luck.
And you say,
A) "Yea, that makes sense. Let me write you a check, or better yet let me Venmo you".
B) "Let me pay a lawyer to decide if I need to pay you for the engine fire Paul caused".
C) "Tell Paul I'll cover half of his bill. That seems the most fair way to handle it".
All of those choices seem wrong.
A Global Settlement Agreement is a comprehensive legal deal resolving numerous similar claims (like from a defective product or mass harm) or all disputes between parties in one master agreement, instead of handling each case individually. Used in class actions, mass torts, and complex litigation, it streamlines the process for large groups of plaintiffs, offering efficiency, quicker resolution for compensation, and finality for defendants, even while often denying fault.
I recently saw a Eaton main breaker that had sticker on it that says it needs 1/32" fiber liner behind the breaker.Do the pictures indicate manufacturer mistake, something left out of this panelboard assembly?
Dear Electric,
On Friday, December 5, 2025 my licensed electrician name x opened our Eaton 400a panel... while tapping out a knockout sparks flew from the 200a breaker .../..He was thankfully uninjured and shut down the main panel and removed all the breakers to inspect. The breaker in question was basically unscathed but the but the bus bars had arced with the metal backing creating a lot of melted plastic and metal. Upon further inspection the vinyl sheething that should have been isolating the bus bars from the metal back of the panel did not extend far enough up to be behind that main 200a breaker. In fact it was strangely duct taped at the bottom as well.
