Nope they both can do either.Does anyone know how to tell the difference in these two types of welders for applying Table 630.11A?
My gut is a nonmotor generator is a "stick" welder and motor generator is wire feed type but I'm just guessing.
Probably more common before rectifier driven types became more popular? The higher the current rating the more common even when there were some rectifier driven types out there?View attachment 2581243
That's a Motor/Generator Welder. You won't find them around much anymore unless you have someone doing heavy DC stick welding, hard facing, arc gouging, etc. They are almost always 100% duty cycle. Very smooth machines as far as welding goes. I think that one is smoother than my Lincoln SA-200 Redface
What's the basic operating principle of a motor generator welder?Probably more common before rectifier driven types became more popular? The higher the current rating the more common even when there were some rectifier driven types out there?
Yeah well I'd estimate the GE one I posted is 1930's to 1940's era and still welds beautiful.Probably more common before rectifier driven types became more popular?
@Joethemechanic
Had one at the shop I worked at. They did a small job for a guy, and he didn't pay but gave the shop the Lincoln welder. Worked great.
I sent it to a job once and was going to go and wire it but the pipefitter called me back and said the electrician on site said he would hook it up.
Then they called me and said it wouldn't work and sent it back to the shop.
Nothing wrong with it. The electrician had cut our cord cap off and hardwired it.
He had the rotation wrong
Same generator used on the Lincoln gas drives AFAIK
Like any M-G set, the motor turns the generator to make a different voltage/current than the line. For welding there's a DC generator with specific characteristics to power an arc (constant current), not provide constant voltage. These were also common in movie theaters to power the arc lights on projectors and in spotlights.What's the basic operating principle of a motor generator welder?
DC generator driven by either an electric motor or gasoline/diesel engine.What's the basic operating principle of a motor generator welder?
Not an arc light or a projector, but I burned my arm bad on running a Strong Trooperette following a funny looking ballerina during a performance of The Nutcracker in 1976. "Pain at first site". I have to hit her with that when she calls tonight.My kind of arc lights-
When I questioned them being even more common long time ago - was because DC rectifiers were not so common at higher capacity like they can be now, or even about 1955-60 or so. If you wanted high level DC current from an AC source might been easier or less cost at one time to drive a DC generator with an AC motor. Today with more availability of high power solid state stuff it is less expensive,lighter weight and more overall efficiency to rectify via solid state components.What's the basic operating principle of a motor generator welder?
