Alwayslearningelec
- NJ
- Estimator
lol. Seems a bit impractical.People complain about 5G, imagine what will happen if something like this is tried.
-Hal
I seen where they have a trial length of roadway set up (can't remember where) with wireless EV charging in the roadway - charge as you drive. Though I think it is something rather impractical mostly from cost perspective especially if you want to have it all over the place, the general comments were complaining about potential EMF issues more than anything else.People complain about 5G, imagine what will happen if something like this is tried.
-Hal
I didn't look at OP link but would think it at least would have to be pretty narrow and directional point to point type of thing rather than being a general broadcast type of thing. If not look at all the energy that likely is lost just in transmission as well as how easily one could possibly steal some of that energy without paying the provider. Signal transmission is low power and any value is in the information of the signal that is being transmitted and can be encoded so it is more difficult to steal that information.How would transmitting this much power ever work with out inducing voltages on a lot of other things.
Just seems almost impossible to my simple little brain.
You think the EMF scared type is bad now, imagine what they would be like with this wireless stuff!the general comments were complaining about potential EMF issues more than anything else.
My phone usually is warmed up even when charged from the wired connection I presume the battery puts out most of that heat?If you ever charged your phone wirelessly, you’ve probably noticed the heat generated. And that’s only transmitting a few watts a very short distance. Now, multiply that by several orders of magnitude!
That’s odd. There is supposed to be a handshake between the phone and charger before it tries to charge.When buying a new car it had an option for a wireless phone charger. The instructions say not to put loose change or other metallic objects there due to possible heating.
Mine gets much warmer on wireless than when plugged in.My phone usually is warmed up even when charged from the wired connection I presume the battery puts out most of that heat?
Yeah but if you manage to put something else metal on the charger along with the phone...That’s odd. There is supposed to be a handshake between the phone and charger before it tries to charge.
The charger powers up when it senses the metal receiver on the phone but I don't think the phone has any way to tell it to power down when the battery is full, so then the power from the charger goes to heat.If you ever charged your phone wirelessly, you’ve probably noticed the heat generated. And that’s only transmitting a few watts a very short distance. Now, multiply that by several orders of magnitude!
