Alwayslearningelec
- NJ
- Estimator
I know spec dictates. But if your running PVC coated RMC and using pvc coated straps, strut and rod would the nuts be pvc coated( do they even make) or stainless?
They make PVC coated rod? We always used stainless steel hardware with PVC coated galvanized conduit.I know spec dictates. But if your running PVC coated RMC and using pvc coated straps, strut and rod would the nuts be pvc coated( do they even make) or stainless?
Yes, they do.They make PVC coated rod? We always used stainless steel hardware with PVC coated galvanized conduit.
Then I would think that whatever system you're using for the rod they would also manufacturer PVC coated hardware.Yes, they do.
How would you PVC coat threaded rod and nuts??They make PVC coated rod?
Just dip it. I guess you would cut off the coating on the ends before you installed the nut.How would you PVC coat threaded rod and nuts??
-Hal
