Rick 0920
- Jacksonville, FL
- Electrical Instructor
The verbiage here has been in the NEC for several years. "Accessory buildings that have a floor located at or below grade level." Does this mean if I built an outbuilding on deck blocks and had even one step above grade level, that I would be exempt from this GFCI rule for receptacles within that building? I'm trying to use some common sense here. If a homeowner were using a cord and plug connected weedeater, I don't think they would run the cord all the way to the house to use a GFCI protected receptacle instead of using the one closer in the outbuilding. Most homeowners don't even know what a GFCI is!!!!
