Thats my question if the screw has to be green why not the wire. BTW I don’t think it specifies it cant be any color including white or grey at least for sbjA wire type can be bare or any color other than white or gray. Same as a GEC.
The function of the screw, because it is often located with other screws, may not be clear without the green identification. The function of a wire type system bonding jumper should be clear to any electrician base on its location in the circuit and its connection point.Thats my question if the screw has to be green why not the wire. BTW I don’t think it specifies it cant be any color including white or grey at least for sbj
Don gave you the applicable code sections. The code is specific regarding using a screw as the MBJ requiring a green finish.Thats my question if the screw has to be green why not the wire. BTW I don’t think it specifies it cant be any color including white or grey at least for sbj
