Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
I know this is a common question that has no answer as you can probably put as many outlets as possible on a circuit that you want.
Back when I was doing houses, I used to follow the 180 va/ outlet so a 15A general use circuit I would put 10 receptacles or 10 lights or 5 receptacles and 5 lights etc as a 15 amp circuit is 1800va.
What is the consensus of what you do? I used to shoot for 10 sometimes it was 9 or 12.. Is this a reasonable approach?
