- Tennessee NEC:2017
- Semi-Retired Electrician
Should you remove leads from capacitors before checking them with a meter? My condenser unit for my heat pump isn't running and I suspect bad capacitors.
Guess that makes us "Master HVAC Techs"!Funny,
For what it's worth I had almost the exact same experience with my heat pump this weekend with the same end result.
Stuck contactor (in open position) should likely have burned out coil when power was applied to the coil.Very strange!
I checked the capacitor, it was good.
I checked the contactor, including the coil. I even pulled it off to check the contacts and coil resistance, all good.
Put everything back and was going to check further. Now I had the disconnect pulled out, but the indoor unit was powered. As I was sitting there wondering what to to check next, I heard the contactor pull in. Had 24V on the coil and contactor working. Put the pull out back in and it fired right up!
Only thing I can think of was a loose connect somewhere, or coil or contactor stuck. So either taking the wires off and back on fixed it, or manually operating the contactor, got it going.
Whatever it was, I hope it stays and I don't have to have a tech come out.
