Section 2 of the UL508A MTR re-qualification exam tripped me up in a few areas, one being sizing field wiring terminals. If the wire material is not specified, I've been using the largest size wire gauge for a given ampacity between aluminum and copper, since the panel builder does not know what type of wire will be used. So for example, if the required ampacity is 35 A, then I would select a field wire terminal size of 6 AWG, since that covers both copper and aluminum. 8 AWG would only cover copper. Is this the right approach?
