When you say painted panel enclosures do you mean grey?My first choice would be QO but I'm on the fence if they're worth the extra cost. Personally I dislike painted panel enclosures and won't use them on something like a service upgrade where there is type AC wiring involved. I used Eaton BR in my own home and I think they're fine especially if you're price sensitive.
Around here the difference in the panel is about $100 cheaper than equivalent HOM.In my area we have a choice of Eaton……
The quality of the BR panels has gone way down since covid. Lugs strip out constantly, and of course, replacements aren’t available.
Everything is extra, like ground bars in an MLO panel, which I’ll never understand. And while the panels are fine price wise, accessories are ridiculously expensive.
However, BR AFCI and GFCI breakers probably have the fewest nuisance trips. CH tend to fail self test.
Yes like Square D QO. Eaton uses galvanized enclosures.When you say painted panel enclosures do you mean grey?
He doesn't like painted enclosures when using AC (or MC) armored cable because the lock nuts on the connectors could have a problem biting through the paint and providing a reliable ground. My opinion is that armored cable has been used with painted enclosures forever. Just make sure your locknuts are tight. Smack them with a screwdriver and your Kleins. It's a recent phenomenon that enclosures are available not painted. Probably as a cost cutting measure.When you say painted panel enclosures do you mean grey?
