Is the statement "Rigid mettalic conduit shall be installed as per ANSI/ASME standard for pipe threads,general purpose" true or false?
The code requires,in 344.28 that it be threaded to 1 inch 16 taper etc.,then in references the ansi/asme standard in the Informational note,does that make the ansi/asme standard required(shall be) by code?
Even if it might be the only way to thread rmc does that make the standard required?
