WattsaVA
- Blountville, Tennessee
- Electrician
I have a job where this guy has built right up on top of a very steep mountain and his water will not pump all the way up there, so he has an “in-line pump" being installed about half way up (1000’ elevation rise with a half mile long driveway).
I need to install the wiring and calculated the voltage drop. For 500 feet it says that I have to upsize to a #3 AWG for a 30A 240V pump. That is four wire sizes increase. I have never been in this situation before and this blew my mind. I knew that I would have to derate it but I thought that it would be one size maybe. #10 to #8.
I read around and found something that I had never heard before and is a little mind blowing too. Supposedly you can increase the voltage considerably to offset, so please help me to understand and tell me if this is incorrect. I can get them to install a 120V pump and run it on 240V and reduce the current by half? Do they even make 120V pumps for this? Also, I don’t know what the voltage or current of the pump is yet. I am just assuming that it is 240V 30A.
Any advice would be greatly appreciated.
