Garmaster
- Kill Devil Hills NC
- Electrician
Question on wiring a pool heat pump. The Mca is 22A and max breaker is 35A. There is a #12 nmb circuit available. Am I able to size the wire on a heat pump based on using the minimum ampacity but sizing the breaker to a larger breaker size? In table 310.16 in the 60* column it says #12 is good for 25A. So basically what I am asking is can I wire this pool heater with #12 and use a 30A breaker or 25A breaker?
