renosteinke
- NE Arkansas
I recently saw a video (search YouTube) discussing Brazilian / South American shower heads that incorporate a modest electrical heating element in the shower heads.
As crazy as it sounds, it seems normal for them to dangle wires in the area of the shower head, then wire-nut the modest leads to the exposed cable. No box, no GFCI, often no ground.
The wires look to be no larger than #12, while the discussion claims a 60-amp draw at 110v. Multiple comments claim there is no record of anyone being hurt by these heads. The heads are claimed to add as much as fifty degrees (Fahrenheit) to the incoming tap water.
It’s an interesting idea. With today’s’ international web-based commerce, I wouldn’t be surprised to find the things at Amazon.
I find the NEC to be completely inadequate for this topic. GFCI? Somehow the NEC does not consider water heaters a serious risk of shock - regardless of the mineral content of your water, the use of metal piping, or voltage. “That’s just crazy” is not a valid code citation. The lack of any UL evaluation is not surprising; they’re an American firm with very limited relevance outside of the USA.
What are your thoughts?,
