trevorm
- Central Washington
- Electrician
Here is an interesting panel replacement job that I'm in no rush to get done. My background is 20 years in mostly industrial high voltage so i'm always trying to learn and see what creative ways others have for solving the same problems in resi stuff. Its an old zinso panel in a house with mixed emt and nm entering it. If it was commercial i'd just use a panelboard with no knockouts but there is no space for the thicker and wider (more expensive) panelboard (max 14.5" width). The cleanest would be if i could special order a load center with no pre-cut knockouts. Next would be a 4x4x12 gutter across the top, that's a lot of time to pull back the wire and cut the conduit. Lastly what I don't really consider as an option would be to use a carbide cutter to cut holes in a stock load center but thats just going to make a mess of mickey mouse ears.
