- Illinois
- retired electrician
The process itself is set by the NFPA and the ANSI rules for a consensus document. They are not subject to change via a Public Input."meta" as in "metadata" or data about data.
A meta comment is not about a specific section, but about the process itself.
Yes, in a number of cases a current section number will be for something totally different, but a larger number of the commonly used rules will remain in their current articles and sections. There still is a particular order in the 2029, but that order is not the same as in the 2026.I will comment that old section numbers could be formally "retired" so new code can't end up with an old number.
That's easier if the sections no longer have to be in a particular order.
I believe that Chapters and Articles are subject to change via a PI, but do not expect there will be many changes from what you see in Annex L in the 2026.
It will still be numerically sequential, but the numbers will change. For example the rules now found in Article 300 will be in Article 200 in the 2029. The only change in the numbers will be that the section number will be 2xx.xx in the 2029 and not 3xx,xx as they are in the 2026. Of course the user will have to be careful, as the new Article 300 contains the general rules for installations over 1000 volts. I am sure that there will be numbers in the new Article 300 that match those in the current Article 300.Ah, then the code will no longer be numerically sequential.
That's an interesting tradeoff.
