DrSparks
The Everlasting Know-it-all!
- Madison, WI, USA
- Master Electrician and General Contractor
I’m installing 0-10v dimmable LEDs and I have a couple questions about he control wiring:
1. I’m using class 2 CL thermostat wire (18-2) for the DC signal. From how I interpret the chapter on power limited wiring is that it’s ok for this wire to enter the junction box on the light fixture through a separate knockout. Anyone care to refute?
2. There seems to be no way to turn the fixture completely off using a DC signal. 0 volts ( or no signal) is full brightness and 10 volts is full brightness. 1-10 volts is bright somewhat proportional to voltage but there’s a plateau where no more dimming is possible at about 2 volts. I discovered by accident that removing the voltage signal and shorting the input terminals in the fixture causes the light to turn off. I tested one off to the side for a few days and it seemed to cause no harm to the electronics. I was wondering if anyone knew of this was by design and meant to operate this way. I could easily put a relay in the control box that disconnects the signal voltage and shorts the control circuit for off operation. The documentation on these fixtures is sparse.
Thanks!
Thanks!
