curt swartz
Electrical Contractor - San Jose, CA
- San Jose, CA
- Electrical Contractor
I know this is a stupid question but I don?t have much experience with 0-10 volt dimmers.
I have an architect that sent me a spec sheet for a single 1? x 4? Cooper LED fixture. The spec sheet specifies a 0-10 volt Dimming LED driver. This fixture is going to be installed at an outlet that is switched with other fluorescent fixtures. I told that architect that we don?t have any wiring provisions for this fixture to be connected to a dimmer. He responded that a dimmer is not necessary for this fixture but the standard driver is 0-10 volts.
My question is what needs to be done if I want this fixture to operate at full brightness without using a dimmer? I know there are different types of 0-10 volt dimming. Some designs would need a separate low voltage power source to the driver for the driver to operate at all. You would need 10 volts for the driver to operate a full brightness. The wiring diagrams for newer drivers show that they can be connected directly to the dimmer without any additional power source. I?m just not sure what needs to be done if no dimmer is used.
Thanks in advance!
Thanks in advance!
