0-10 volts is not 0-10
PWM can cause flicker at low levels, so some high end dimmers will do PWM down to a certain level and change over to adjusting the current from that level down to off.
/mike
What is PWM'ing the current or combination?
PWM means "Pulse Width Modulation". To get brightness between 0 and 100%, lights are turned on and off rapidly with a square wave. Brightness is proportional to the "on" portion of the square wave's duty cycle, i.e., its pulse width.
