dpcarls1598
Master Electrician
- Minnesota, USA
- Master Electrician
I am currently retrofitting a large classroom with 2x4 LED troffers from Cree. I have been using dimmers (0-10v) for the other rooms but this room is fed with two separate 277v circuits due to it's original lighting load. The dimmer I am using can handle 60 fixtures (only using 28) but one row is on a separate phase from the others and they only want one dimmer.
I have called Cree and Leviton (dimmer manufacturer) and both have not been able to answer this question...
Can the 0-10v dimmer wiring jump from drivers on one phase to another or will that damage the driver/dimmer? Anyone done this? I can rewire the room but not in the amount of time I will have for the job.
Thanks in advance and yes, it's my FIRST POST!!!!
