rojay
- Chicago,IL USA
Can anyone find a code section that would prohibit the use of a listed fitting to change over from 1/2”EMT to 3/8”FMC?
The application that I have in mind is a typical residential hard-wired dishwasher connection that complies with 348.20a guidelines (less than 6ft and supplying utilization equipment).
I understand that a Bridgeport 280-DC fitting that is intended for use to transition from EMT to NM cable is an obvious code violation but multiple manufacturers (including Bridgeport) make listed fittings for the application.
I’ve been told many times that there is a code issue with the transition from 1/2” EMT to 3/8” FMC but have never found anything in the code that supports that claim. A problem with the reduction in raceway size perhaps?
Any thoughts?
Any thoughts?
