jdou
- katy, texas
I have connected a 120v 1/2 hp 1350rpm 5.5a motor for a rooftop exhaust fan. I have a disconnecting means at the motor on the roof. I was going to put a 20a single pole switch as the controller in the lease space, but the ac installer discussed with the customer to put it on a rheostat to control the cfm's. I haven't really read the literature on the fan motor but looked at the nomenclature and did not see anything readily apparent about varying the speed of the motor. I recommended to the customer to install dampers in the duct as opposed to varying the speed of the motor as from what I see the motor is designed to operate at 1350rpm and there may be risk to the motor to do otherwise. Is there anything I can look for that would indicate using a rheostat safely on the motor? Thanks
