Re: 1/3 nuetral versus full nuetral
I've seen 1/3 concentric neutrals for URD cable for primary utility power. Our POCO requires 100% concentric neutrals even for 3 phase services. If your talking about primary feeders from the utility to a utility transformer, you should ask what is required by the utility. They will spec the cable required including the % neutral, mils insolation, jacketed/unjacketed, size conductor, type insolation, voltage etc.
