designer82
- Boston
I need to install a 3 PH food processing machine on a one phase system and need a converter. The food machine requires a neutral for the onboard electronics.
1st queston: Can I wire the machine as shown on the picture and run the neutral directly from the main panel, will this work?
2nd question: If the machine is pulling about 40 amps on the single phase panel, will it be pulling about 23 amps (40/sqrt 3) downstream of the converter? (therefore smaller cables downstream of converter)
Thank you
Note, lastly.. can you recommend any good quality 1 to 3 ph converters?
Thank you
