I need so help. I have installed some small transformers primarily for control voltage or Lv panels. I understand transformers to a degree but I don't understand the single phase 480v. To set the the scene, I have 3phase 4 wire and need to get 120v w/neutral. I know I can use a 3 phase transformer, that is not the question. What I will use is a 3kva transformer and the client doesn't want the transformer mounted outside of the panel. Also, they have already purchase the 3 panels that they want to use for this job buy copying panels designs that they purchase for their robots because they seen that they could get what they needed from them. 480v in and 120v and 24v out. Then they wanted to take that and add what they wanted and I don't want to fit everything so tight. It is complete mess and is one of the largest companies in the US if not the largest and I could make them buy the correct stuff. So I am wanting to know..... With a 3kva transformer can I use 1Ph of 3Ph of 480v to get 120v with neutral. This would allow me to mount and install this much easier and better for various reasons. The load will be no more than 15-20amp and I don't think I should be concerned with unbalancing the 3ph 480v by using only 1Ph but correct me if I am wrong. This branch of 480v will power some other circuits for drives that will have no more than 5hp motor connected to them. The 120v circuits will be used for auxiliary devices. This is a testing center so it might be used once a day or once a week but none the less the load will not be continuous and the load on the 120v circuit will either be maybe a amp or 2 while the 3ph 480 circuit is being used. I'm came across this before but never found out if I had option here and I haven't seen it in the field. Sorry for the long drawn out scene just trying to explain the mess. I may have missed some need info so let me know If I did.
