maxrep99
New member
- temecula, ca, usa
I'm looking for something that is very expensive or I need to get the correct components together.
I am just a hobbyist. Currently testing wind charge controllers that activate only when 3 phase AC is between 10.5v and 14v. (going to 12v dc output)
Is there ONE unit that has 110 1 phase AC, 60hz input, max 10 amps.
Output is variable or programmable.
- max 300 watts
- voltage can be set to 1-220 3 phase AC
- Hz can be programmed between 1-200 hz. will settle for 50-60hz
I am not driving any motors, so startup load is not a consideration
any ideas ?
Thanks
- max 300 watts
any ideas ?
Thanks
