10 AWG and 40A square D breaker
  • Ignore the restriction and put the 10 on the breaker
    Votes: 10 40.0%
  • Use a wire nut to splice and 8 onto the 10 in the panel
    Votes: 6 24.0%
  • Some other splice method for an 8 (explain what)
    Votes: 2 8.0%
  • Some other method (explain it)
    Votes: 7 28.0%
  • Total voters
    25
I would think that most of us (without looking) would assume that a #10 would fit tightly in a 40 amp CB.
Dennis Alwon said:
I just went down the basement and pulled out a dp 40 GE and an old Sq. D DP 40. The GE does not mention wire size but the SQ. D does )#8-4. I needed reading glass as well as a magnifier to read the darn thing.
Anyway I put a 14 wire under the sq.D 40 and I gotta say there is no way in the world that connection would come loose. I whirled the breaker around by the wire and it was still "snug as a bug in a rug". So why is it listed for #8-4???
I guess I would have no problem defying that listing. Sorry-- kill me-- go ahead.
Thanks alot Dennis !!! :D ,, i end do the same thing what you did i try the same way took a old QO 240 breaker and do the same way as you desecrbing but kinda odd it really clamp the #10 and i try that again with #14 also still stick on good.
but IMO for proper way i will either wirenutted a short pigtail or poloris it
Merci , Marc
You could always use a Cutler-Hammer CHQ or CL type of "classified" breaker in those Square D panels. Me thinx their lugs will accept a #10 in the 35-60 Amp breakers .... :grin:
...on a QO?
Thanks for the replies. I expected this to not be well known, but a little surprised so many would ignore the listing. An extreme example, but put a 14AWG in the largest lug you know about and torque to the proper value. I would guess the wire would be flattened. Just because it holds doesn't make it right. In this particular case though, it might just be square D chose not to test smaller than an 8.
I plan to splice an 8, but not sure I would trust a wire nut. A split bolt would be cheaper than a polaris, but I'll probably use the polaris anyway. I stumbed on an old thread that suggested there are split bolt 'covers' so they don't have to be taped. Anyone heard of that and who makes it? I haven't been able to find such a thing.
Oh, and I was looking at QO, but I looked an homeline is the same. And they are HACR rated.
Any breaker that meets UL 489 is now HACR , stated on the breaker or not
[SIZE=-2][PDF][/SIZE]
Data Bulletin
[SIZE=-1]File Format: PDF/Adobe Acrobat - View as HTML
UL had Listed these circuit breakers as HACR Type ... to redefine the test parameters for UL Listed HACR Type circuit breakers. ...
ecatalog.squared.com/pubs/Circuit%20Protection/Molded%20Case%20Circuit%20Breakers/0600DB0102.pdf - Similar pages[/SIZE]
breaker
breaker
talk about ammo for the ole charge "if an inspector wants to turn a job down, he can find reason"
I'd hate to guess how many times this violation has slipped by me (and to be honest, will continue to... go ahead, hit me!)
I picked the fourth option - simply run #8 the whole way to the condenser. :D
If the run is short, the price difference is inexpensive - if it's long, then voltage drop will begin to become an issue. Either way, the 8's the easy way to go. ;)
Why would anyone want to hit an inspector that uses some common sense?
Same solution, different reason.
A) Often don't know exact size of unit, so #8 good for up to 50 amps, very rare to see one larger (for me anyway)
B) Company I work for wants wire to match breaker, not min. cir. ampacity. :-?
